Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
LCD Screen Refurbishing Problem #1
I just got into refurbishing screens a month ago. After seperating my 6s glass from the lcd I tested the lcd by connecting and it functioned well. I was having trouble finding an OCA remover so I began reading threads and heard WD40 and goof off worked well. I used a bit of WD40 and goof off ( separately a different intervals) but was worried it was too strong so I was careful with how much I used. After the OCA came off and lcd was clean, I plugged in the screen and there is now what appears to be some wavy ridges when the apple sign pops up towards the top and sides of the screen . Why could that be? Did I apply too much pressure? Did what I used get into the back light or mess up the lcd itself? Is it because I need to remove and put in a new polarizer? I noticed these ridges or wave like things are only visible through white light( first picture) other then that the lcd quality is perfect when displaying colors (2nd and 3rd pictures). I personally don’t mind them but a customer might. I’ve since bought 8333 OCA remover and was gonna use but I wanted to ask the forum before I tried removing OCA again and potentially ruin another good lcd.
thanks!
best,
mrjrizo
Add a comment
1 Answer
Chosen Solution
Usually the wavy lines on white background are from too much heat when separating glass, try 65-70deg.
Try the 8333 but don't just squirt loads on, apply it onto a dust free cloth placed on the LCD so to minimise it getting behind the backlight.
1 Comment:
@bobcat1981 thank you! Is there anyway to save that particular screen from these wavy lines and continue the refurbishing process on? im going to try 65-70 degrees from now on, at first maybe i thought that those wavy lines were because of the pressure i was putting on it when i was cleaning the OCA. I hope theres a way i can save it I'd hate to throw this LCD away! Is it worth it finishing the refurb process on this particular lcd? can i save it and get rid of the wavy lines? if so how?
by
Add a comment
Add your answer
Javi Rizo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 118
