Device name is Jensen 3 speed stereo turntable. Model is JTA-230.
9 Questions View all
Why won’t regular headphones and earbuds fit in the headphone jack
We recently purchased this model turntable specifically because it has the built-in headphone jack. However, regular headphones/earbuds won’t fit the jack. Do I need to buy an adapter or return it?
Add a comment
Most Helpful Answer
@sharpmom teh Jensen JTA-230 uses a 3.5mm headphone jack which is pretty much standard for headphones. The question now is what size is the connector on your headphones/earbuds. Measure the diameter of your connector and let us know what it is. Or post some images with a measuring tape next to it so we can see what you are dealing with. It is not the JTA that is unusual. If nothing else maybe you have a make and model for your headphones/earbuds Adding images to an existing question
Score 1
Add a comment
Buy an adapter. That is the first thing I would try.
Add a comment
Add your answer
Christine Sharp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 90
