The iRobot Roomba 880 is an autonomous vacuum released in 2013, with greater power and cleaning capabilities compared to the previous models.
9 Questions View all
4 year old Roomba 880 squealing while running
UPDATE:
thank you for all your responses we determine that it was the side brush motor. Ordered a new side brush motor and No More Squealing! YAY
Again, thank you all for your help
My 4 year old 880 has starting squealing/screaming while running. I’ve cleaned everything but still scrams. I’m afraid it’s the motor, any suggestions
Score 1
1 Comment
Thank you! That’s what we were thinking too.
by
Add a comment
Chosen Solution
It’s probably the motor, if you’re an expert, you should take it apart - but for most of the time you should ask the previous owner, or company if they can fix it.
Again, what I always say “look it up!”.
Looking it up might not work…
1 Comment:
Thanks for seeing this! :)
by
Add a comment
I had a squealing noise in my Roomba too. which I could trace down to the gearing of the extractor brushes.
The motor was slightly displaced so that the gears didn’t connect properly. I was able to fix this temporarily by adjusting the motor with a piece of plastic. but the gears were worn down already so that I had to replace the extractor housing (including motor and gearing). was not a lot of trouble and is totally doable!
I found the housing in the Roomba shop, but it was a hidden link I only found using google… I am not shure what the situation is where you come from but here in Germany this was also the cheapest offer!
1 Comment:
https://shop.irobot.de/de/cleaning-head-...
thats the part I bought for ~45€ while Amazon and Ebay were >60
by
Add a comment
Add your answer
SueWormington will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 2,881
