The Samsung Gear S3 Frontier (SM-R760 & SM-R765) is a high-end smartwatch designed to reduce the need for your cellphone. Released in November 2016, the device has a 1.3" display, a dual core Exynos processor, and a custom Tizen operating system.
Waterproofing S3 after replacing the back cover
Will I be able to re-waterproof my S3 Frontier after replacing the back cover?
Add a comment
1 Answer
Yes, if you use the proper adhesives that meet or exceed the original adhesive. Your install job must be perfect or it’s water resisting abilities will be reduced or nullified.
2 Comments:
Can i ask what adhesive ?
by
@Cody Tokos B7000 glue is typically used by technicians. Use this glue, clamp it tight and vacuum chamber the phone for best results.
by
Add a comment
Add your answer
Steve Kelley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,077
