4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Flashlight doesn't work but camera and buttons works perfectly
Hi! I have iphone SE and I was changing my housing space and every single piece of it besides logicboard. Everything works great besides flashlight. it’s not working when im opening camera or trying to turn it on in menu. I have two cables with flashlight but in one upper volume button doesn’t work and flashlight in otherone that I insternt now only flashlight doesn’t work. I’ve tried reset, update my iphone and retore to factory settings. Nothing worked. Please give me some advice what could be the problem.
Score 1
Add a comment
1 Answer
Chosen Solution
Those flexes are very fragile, it’s possible that both are damaged or defective. You will need a third one to determine if the issue is flex related or not. You should also check the connectors to see if there is any damage or debris. Also take a close look at the surrounding components to insure nothing has been dislodged from prying up the connectors.
Score 3
1 Comment:
Is there a relevant replacement part we can order if this is the issue?
by
Add a comment
Add your answer
Jakub will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 77
