The DOSS SoundBox can be identified by its model number: DOSS SoundBox on the base between the feet of the speaker. Its a fourth generation bluetooth wireless audio player that was released in 2016.
24 Questions View all
How can I get the charging port on my sounbox pro replaced?
The GND pin in the micro usb port for the charger is severed. I think it broke while I was struggling to plug it in. The port has been giving me issues for a few months now and I've been using a very fine blade to move the pins back in place to line up with the slot in the charger. Now I need to replace the port because this piece is missing. I’m not good with electronics; I definitely can't do this myself.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @cj_97 ,
Contact a reputable, professional mobile phone repair service or an electronics repair service and ask how much it would cost to remove/replace the USB connector only, if you bring the motherboard only to them as you will dis-assemble and re-assemble the speaker.
Doing it this way should save you some money as the labour time will be greatly reduced. Mind you the repairer cannot test their work to see if it is OK or if you have created another problem in the dis-assembly/re-assembly of the speaker. That’s the risk you will be taking doing it this way
Here’s a link to a video - start at about the 22:00 minute mark which shows how to dis-assemble your speaker.
Here’s a link to the ifixit DOSS SoundBox Motherboard Replacement guide which might also be helpful if it is similar to the Pro model. I don’t know if it is or not.
The tricky part is getting the exact USB connector replacement which will fit onto the motherboard. The pin out is always the same but the board’s USB mounting lug position can vary. Hopefully the repairer will have some different USB connectors in stock and one will be compatible with mounting on the board.
Score 2
1 Comment:
Thank you so much!!
by
Add a comment
Add your answer
Connor Tyskiewicz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 926
