Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
Wrong file TWRP bootloop
Hi,
After install TWRP from Odin my Note 9 was stay on bootlop 'Samsung Logo' and restarting, i can't go to Download Mode and Recovery but phone only restarting bootloop.
It happend after install wrong twrp files (\twrp-3.3.1-1-star2qltechn.img.tar) i have select on Odin "Rebooting"
What's going now? Regards Thank you for help
Recovery and Download doesn't work, i can't going to him.... only restarting *****
video: https://streamable.com/k242c
Score 1
2 Comments
Hi Eda Ea, did you able to fix the problem , I faced the same one
by
Hi eda ea
i have the same problem
were you able yo fix your phone?
if yes, could you please tell us how?
thank you
by
Add a comment
Most Helpful Answer
Turn it off full power off take cable out hold volume and Bixby whilst holding plug in USB
Score 2
2 Comments:
After a failed attempt to remove the battery and ending up cracking the back glass, what you said was the solution. Just ONLY hold volume up and bixby, then plug in the USB. Thank you very much!
by
i cain't turn off my phone it just go off and on on logo after it's off i plug it in and it starts again. holding buttons doesnt help
by
Add a comment
Hi Eda ea !
There is always a risk when ROOT a smartphone.
Did you try the recovery mode with the following commands :
Volume Up + Bixby + Power key together for a few moments
4 Comments:
I waiting for battery runs out of charge.  And push Volume UP + Bixby + Connect Cable USB, was starting to Samsung logo and bootloop…. i installed TWRP from other model (A6+) my misstake… and have select option in odin Nand Erase and Auto Rebooting…
by
Indeed, if the wrong TWRP model has been installed.
A reset factory will have to be done.
I suggest you consult this link: https://www.hardreset.info/devices/samsu...
by
Not possible it’s same problem….
by
If even this procedure does not work, I am afraid there is no other solution, unfortunately. Maybe another member will have a second solution.
Good luck with that!
by
Add a comment
please help me i have the same problem
Add a comment
Add your answer
eda ea will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,248
