The Asus X200CA laptop is 11.6 inches and weighs 2.6 lbs. It comes with a either an Intel® Core™ i3 3217U Processor, an Intel® ULV Pentium® 2117U Processor, or an Intel® Celeron® 1007U Processor, 2 GB or 4 GB of RAM, 320 GB to 1 TB of storage, Windows 8 OS, HD webcam, and an estimated battery life of 3 hours.
7 Questions View all
Screen is black, computer runs
I had tried a lot of methods I’ve read, for example the ones where I need to remove the battery and hold the power button for several seconds, even minutes, also the F2 + power button and there’s still no response. I was able to connected to my TV. I read somewhere about going to system manager and deactivate the intel graphics. I did that and then i activated them again and I was able to see both screens. I unplugged the Tv did some work on my computer then turn it off. The next day, I turned the computer back on, and was the screen again black, I repeated the method, and it worked. I just feel unnecessary to repeat this process over and over again, does anyone has an idea what do I need to do
1 Comment:
Are you remembering to save your changes if appropriate? Might also want to check your users manual to see if there is a function key toggle for switching between external and internal monitors.
by
Add a comment
1 Answer
If you can get a display signal to your TV then I’m pretty sure the laptop screen is almost completely dead.
Add a comment
Add your answer
Javier Portillo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 109
