Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1212 Questions View all
iPhone X Face ID repair/replacement
Need help to replace or Repair Face ID
My iPhone X 256 GB face ID is not working after a water damage, phone is working perfectly except FACE ID, apple denied repair. Is there any way we can repair Face ID. I can't replace my mobile by paying $500
2 Comments
Just Face ID or the entire front facing camera assembly?
by
I am so tired for unlock Face ID ,can you know someone how to fix Face ID !
by
Add a comment
Chosen Solution
In theory yes but realistically no. If you need to ask, the training and tool cost for you to start off definitely costs many times more than $500, so no.
Score 2
Add a comment
it’s possible but it requires microsoldering experience and equipment. if the module is still functional, but the flex cable is bad, for example, you could cut off the module and solder onto a replacement flex (may have to be an OEM flex, but I’m not sure).
it’s a pretty intricate repair though and definitely isn’t a DIY process.
also it depends on why the face id isn’t working. I only detailed one explanation, but if it’s something on the motherboard for example, you’re getting into even more dangerous and expensive territory. and a lot of places that I know of don’t offer the same kind of warranties on liquid damaged devices because depending on how bad the damage got the device could have a heavily shortened lifespan.
Score 1
Add a comment
Face ID parts are complicated and difficult to repair. To fully understand Face ID, you can check below.
Why Face ID Not Working After Repair
And for a detailed repair process, you need to pinpoint the faulty component first. Whether the flex cable has been ripped-off or relevant component has missing. Hope the following repair guide can help you somehow.
  1. Face ID not working caused by a broken infrared camera module flex cable: How to Fix iPhone X Face ID Not Available
  2. Face ID Not Available because of a missing component: How To Fix iPhone 11 Pro Max Face ID Not Available - Motherboard Repair
  3. Face ID Not Working After Screen Replacement - also flex cable broken: How to Fix iPhone X Face ID Not Working After Screen Replacement
iPhone X Image
Guide
Difficulty:
Moderate
iPhone X Image
Guide
Difficulty:
Difficult
iPhone 11 Pro Max Image
Guide
Difficulty:
Moderate
Add a comment
https://www.sosav.com/guides/mobiles/iph...
a pretty easy guide on how to repair it
2 Comments:
Unfortunately it appears SOSav has discontinued their English language site. The guide is still available, but only in the original French. In conjunction with the automatic translation feature of the Chrome web browser, it still works quite well even if you don't speak French.
https://www.sosav.fr/guides/mobiles/ipho...
Or you could use the guide I wrote for that same repair.
iPhone X Front Camera Assembly Replacement
by
By the way, this repair WILL NOT FIX FACE ID! The IR camera and dot projector are both paired to the motherboard so replacing the front camera assembly will permanently disable Face ID. Only Apple can replace those parts and restore the functionality of the Face ID system.
by
Add a comment
Add your answer
Vikas Reddy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 44
All Time: 28,543
