Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Static noise when calling
Hi,
So I fixed a water damaged iphone 6s,changed screen, battery, charging port and WiFi antenna and removed a shorted cap, the phone works perfect apart from when I make a call the person on the other end can hear static,
Any ideas would be great.
Thanks
Andy
Add a comment
Chosen Solution
test using voice memos. if you can record voice memos with no static sounding then the mics are okay and the fault likely lies with something in the network capabilities. maybe a new antennae but more likely board damage caused by the water
Add a comment
Most Helpful Answer
Have you tried another earpiece speaker or front camera assembly? If either are liquid damaged that may be causing the problem.
iPhone 6s Front-Facing Camera and Sensor Assembly Replacement
iPhone 6s Earpiece Speaker Replacement
iPhone 6s Earpiece Speaker Image
Guide
Difficulty:
Moderate
10 - 25 minutes
iPhone 6s Front-Facing Camera and Sensor Assembly Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 1
2 Comments:
Thanks for your help, I'll give it a go later and let you know.
Andy
by
Hi,
So I removed the front camera and speaker and the static is still there, I did disconnect the charging port and the noise disappeared so I thought was maybe a dodgy port, so tryed another but still the same issue, any more help would be appreciated,
Thanks,
Andy
by
Add a comment
Add your answer
Andy mck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,190
