The HP Color LaserJet Pro MFP M277dw is a color laser printer with scan and copy functions. It has a model number: B3Q11A
13 Questions View all
Where does small black plastic fuse holder on the fuser assembly go
I had to take apart the fuser unit on my LaserJet Pro M477 to remove a bad paper jam. In doing so a small 1” black piece of plastic fell out containing what appears to be a fuse (looks a little like a thick SD card). I can’t figure out where it goes. I dont see anything that the contacts on the fuse cartridge would connect to.
Any help (or a picture) on where this goes would be appreciated.
Below is a picture of the part. I believe the blue component inside it is a fuse.
Aprox dimensions are 1” x .75”
2 Comments
Might want to add a pic to your query so that the component in question can be identified easier.
Adding images to an existing question
by
May I know how did you take apart the fuser unit? I think I have some paper stuck inside the printer at rear area where the fuser unit is blocking and it's impossible to reach inside with my fingers... I don't really know how to go about removing the fuser unit so I hope you can help me somehow.
by
Add a comment
Chosen Solution
Figured it out
Score 2
1 Comment:
good for you
by
Add a comment
Most Helpful Answer
Sounds like the Duplex Model. That’s #6 in the upper left hand corner of this parts diagram, and it goes into the fuser:
https://printcopy.info/?l=en&mod=pc&bran...
Score 2
1 Comment:
I dont think that is the part (#6). prop man had a good idea, to post a picture of the part. I wont be in the office tomorrow but will add a pic on Friday unless someone else has a suggestion before then
by
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 428
