Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
Ice maker not making ice
My ice maker only makes like 8 cubes a day. I have changed the filter. Our water dispenser works great please help
Score 1
1 Comment:
Hi @cherpauline ,
What is the make and model number of the fridge?
by
Add a comment
1 Answer
Usually it’s a controller board issue. The manufacturer,such as lg,generally sells replacement parts. Inside of the door(between inner and outer pannel),usually,there is the controller board.
Add a comment
Add your answer
Cher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 59
