Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Is battery adhesive necessary?
After performing a screen and battery replacement, I realised I forgot to adhere the new battery down to the casing. However, I've not notice anything adverse since doing it. Should I have stuck the new battery back down? What is the consequences of not adhering the new battery down?
Apologies, my Google Fu has failed me today.
Add a comment
Chosen Solution
It is not necessary,but recommended. It can rattle around a little bit and could bump against the inside of the screen. Really,it would be annoying to have it rattle around,and it could bang the screen. Overall,you definitely can get by just fine without replacing it.
Score 3
Add a comment
Need adhesive. The cable from the battery will get damaged overtime. Even using scotch tape in a loop is better than nothing to stick both sides.
Score 2
1 Comment:
I'm replacing the battery in my iPhone 6S for the second time. The tape is supposed to stretch and slide out, but the ends just rip off leaving the tape goo under the battery making the battery almost impossible to remove without destroying the phone. Maybe that's real purpose, so that you have to buy a new phone. So far, I've been lucky, but I'm not going to put both strips in, just a small part of one strip in the center. Two strips is way over-kill.
by
Add a comment
Add your answer
Casey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 26
All Time: 1,201
