Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
454 Questions View all
Why is my iPad keep turning off while charging at 1%
so my iPad is dead, and I charge it. every single time when it hits 1% it start the ipad. and then it just turns off because the battery ran out. and then when it charge to 1% it just goes in a loop
Add a comment
Chosen Solution
It might be simply the battery worn out and doesn’t take charge anymore. Make also sure you’re using the right charger, a 1A charger as that for the iPhone wouldn’t be enough to charge an iPad flat battery. Both possibilties would produce the symptoms you’re describing.
Score 4
1 Comment:
Thank you! I was using my iphone charger to charge my dead battery ipad, which wasn't working. Got my problem solved.
by
Add a comment
Try powering it off quickly when it turns on, and wait a little while before finally turning it back on. Your iPad should now have more charge to keep working
1 Comment:
How can I identify which cable/charger came with my iPad?
by
Add a comment
Add your answer
Blockcity 4k will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 233
All Time: 13,728
