Repair guides for the MacBook Air, Apple's current line of consumer laptops.
4870 Questions View all
Does anybody know how to get stripped Pentalobe screws out?
I was replacing the battery when I over-tightened one of the Pentalobe screws on the outside. I stripped it. Now, I can’t get into the computer to do any other repairs. Let me know if anybody has any methods to remove stripped screws without damaging the laptop, and if anybody knows a site where I can buy a replacement screw.
Edit: The screw head is stripped but not the threads. I can’t unscrew it and I can’t pop it out.
Add a comment
1 Answer
Most Helpful Answer
Remove all the other P5 screws. now you should be able to lift the cover enough to pop the screw out.
Score 1
2 Comments:
The threads are not stripped, but the screw head is. I can't pop it out but I can't unscrew it either.
by
@chanute You have to cut a notch in it and use a flathead. I do this with a type of Dremel tool with a cut off disk attached. The disk is round, so if you are careful all you will cut is the screw since it is recessed.
by
Add a comment
Add your answer
Chanute will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 112
