I cant reset bc space is needed on the drive and I forgot password
How can I get past my password to login bc I tried to reset and it wont allow me bc space is needed on drive
Hi @lilllady
Most android tablets have a way to reset the tablet within the boot loader. Try following these steps to reset the device:
NOTE: Doing this will clear 'all' the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the device.
Be sure you back up any data you want to keep, to a computer or cloud account, before doing the reset.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Remove your SD card, if there is one in the device.
3. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
4. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
5. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
6. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
7. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
8. Then press the "Power" button to hard reset the tablet.
9. If you took your SD card out in step 2, when the device is up and running again, reinsert the SD card.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 454
That unit has a SD slot. Put a SD card in it and see if the factory reset will utilize it as additional storage.
by prop man
