This Asus laptop is a 2-in-1 touchscreen laptop. It can be identified by its model number: Q504UA-BHI5T13.
11 Questions View all
How do I fix or replace a hinge
This is the 2nd time my hinge has broken. First time I had Geek Squad fix it and they just sent it out to their main center instead of in store. This time I want to try to do it myself. The hing works but as I close the screen, the top cover separates from the LCD by the hinge. Do I need to replace the hinge? If so, how?
Update (09/16/2019)
It looks like this. I don’t even know how to get the display cover off. It almost looks like I can just attach the LCD display top better, it will work fine.
Score 1
Add a comment
1 Answer
Most Helpful Answer
it would be great if you could show an image
Is this the type of hinge you are speaking about
You need to replace the hinge. trying to repair it is a not the way to go
You should find one on ebay
Also a screw holding it in place may be missing
Score 1
Add a comment
Add your answer
Rob Zeigen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 292
