The fifth generation van had debuted at the 2007 North American International Auto Show with exterior styling by Ralph Gilles.
28 Questions View all
Replaced belt now I have water coming out.
Serpentine belt shredded it self. I was able to replaced it myself. But now I have water coming out all over the ground. It wasn’t leaking before I replaced the belt. Any idea what it could be?
1 Comment:
Did you remove the water pump or loosen it while putting the new belt on?
by
Add a comment
1 Answer
You need to prove where the water is coming from, it happens that when you replace a belt that the extra good tension is on the water pump, the bearing shaft seal will start to leak but make sure where the leak is coming from, fix that and your good, did you accidently put pressure on a hose and tear the hose a little?
Add a comment
Add your answer
Greg Thompson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 73
