Fifth generation of iPad, released in March 2017. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A9 processor.
167 Questions View all
Accidentally ripped home button flex cable opening iPad.
I was changing the screen for a coworker on an iPad Air 5. I’ve done a screen replacement twice for them but this time I accidentally forgot to disconnect the home button ribbon and yup it got sliced in half.
Does TouchID stop working on iPad if you use a new cable? Is there a way to splice them?
Score 1
Add a comment
Most Helpful Answer
you may be able to splice the existing cable to a replacement. however the replacement would most likely need to be an OEM one from another broken device or such, and would require microsoldering equipment/experience.
a replacement home button may not have touch id but it’ll still work fine as a home button
Score 3
1 Comment:
Yes I’m facing the same problem. I’m trying to source another cable to splice two together to make one. I’m under no illusion I know it’s very difficult.
by
Add a comment
Very simple answer to this question
No you cannot splice them and you lose you fingerprint ID
It may be possible to connect the broken cable together but you would want to be very good a microsoldering
Even at that is it worth the time doing it
Score 2
Add a comment
Add your answer
Baldemar Orozco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,716
