First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
72 Questions View all
Where to find a replacement charging port for 1st gen iPad 3G?
I can only find replacement charging ports for the Wi-Fi only model, which explicitly states it will only work with the Wi-Fi only model. Is it really incompatible with the 3G model? Where can I find a charging port for the 3G model?
Add a comment
1 Answer
Most Helpful Answer
@defurni you are looking for the dock connector cable. We need to know what iPad you have A1337 or any other numbers on the back of your iPad? Yes, the cable would be different because of layout and connector differences. Looks like your cable would be a 820-2701-A so check on here
Score 2
Add a comment
Add your answer
donald furnival will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 67
