The Alienware 17 R4 (17.3 inches) is a gaming laptop, released by Dell in 2016. (AW17R4-7000SLV-PUS)
21 Questions View all
Alienware 17 R4 not powering on, power button and keyboard flash only
i just picked up this alienware 17 R4 which isn’t powering on. i have the correct charger.
the power button illuminates blue along with the alienware marque and the keyboard, then the machine cuts off shortly after.
if i pull the RAM, i get the correct diagnostic LEDs for no RAM, and the machine stays on. if i pull the CMOS battery, i’ll get the correct diagnostic LEDs for bad CMOS battery after a few power on attempts, but it still cuts off. i have replaced the CMOS with two different known good batteries.
i have disconnected all power sources and held the PWR button for 30+ seconds with no results. i have attempted to power on with batt only, AC only, and both.
i have also tried known good ram from another dell i have, as well as tested both 8gb sticks in the other dell. all ram is good.
any ideas?
1 Comment:
i'll also add, that after scrubbing down the ram chips and the ram slots, if i power on the machine with only one stick in dimm2, i occasionally get the LED sequence for "ram error." this mainboard is probably toast
by
Add a comment
1 Answer
Have you tried turning it with hard drive and battery disconnected?
1 Comment:
Yes, I’ve tried powering on with all possible batt/cmos/ac configurations, as well as RAM and HDD.
My next step is to flash bios with SPI programmer
by
Add a comment
Add your answer
Ronnoc Nailli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 493
