Whirlpool Gold Series Dishwashers can be identified by model number WDF750SAYM0, WDF750SAYM1, or WDF750SAYM2.
22 Questions View all
Why is water leaking from under the door?
Whirpool dishwasher model GU2275XTVB1 leaks from under front door. Sometimes during wash cycle, sometimes during rinse; sometimes a little and sometimes quite a bit. And sometimes not at all.
Add a comment
1 Answer
Most Helpful Answer
@jsexton this is hard to answer since it is inconsistent and intermittent. I would suggest that you check the bottom of your dishwasher and where the water supply lines enter. Check for cracked/split hoses and tighten all clamps and connections. If unsure what you are looking at or what part it may be you can alwyas post some pictures with your question Adding images to an existing question
Score 2
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 208
