Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
315 Questions View all
My old MacBook air show blue colour only.
my old macbook air show blue colour only, even if i plug it to external display, its only show white and black colour.
its that because GPU fali r smothing else?
Update (09/28/2019)
when I try to plug to externadl display its show like this
after login its, become like this
2 Comments
Yep - Either corrosion on the LVDS connector or a damaged internal display
by
ok, thanks @danj
by
Add a comment
1 Answer
Chosen Solution
At this point you’ll need to check your logic board displays connection. The LVDS connection may have corrosion damage and/or the cable is damaged or the display its self.
I would also try an external display to see what it shows.
Follow this guide MacBook Air Models A1237 and A1304 Display Assembly Replacement to Step 3 then jump to Step 23 disconnecting the cable and inspecting the connectors for damage.
Given the age of this system it maybe time to upgrade to a newer system (used or new).
Score 2
Add a comment
Add your answer
mars erik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 85
