This Apple Cinema Display is characterized by the M8149 model number and was first released in July 2000
7 Questions View all
Erase mark on screen?
A Sharpie permanent marker touched the screen of one of my Apple Cinema Displays, leaving a mark about an inch long. Does anyone know the best way (any way) to remove such a mark with no (or the least possible) damage to the screen?
Maybe a chemical that will react with (remove) the black mark while not harming the display (or not too much), applied with Q-Tip or something? Magic Eraser? Any ideas?
Add a comment
1 Answer
Chosen Solution
Use a LCD friendly spray to do it. Alcohol works too. For Sharpie, I'd use alcohol first since it usually works. Rubbing the screen would work too, but be careful what you use to do this. Some things damage or scratch the panel.
If this doesn't work, then leave it. You'll do more harm then good.
Score 3
2 Comments:
+ for the editing..try for the fourth, it's subtle..
by
Anodex is a product that seems to be highly recommended. Anyone have any experience with it?
by
Add a comment
Add your answer
John Brandt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 835
