Patagonia outerwear that keeps you warm on brisk days and dry on wet days. Repair difficulty ranges from simple tear patching to more complicated baffle repair.
147 Questions View all
My Coat is Shedding White Dust
I recently purchased a used vintage coat and have found that a harmless white dust sheds from the interior layer of fleece. After washing and vacuuming the jacket it seemed to be fixed but after a day the dust appeared again. Any ideas on what may be happening? Thanks.
Add a comment
Most Helpful Answer
Use lint roll ons on it and read the washing instruction, if any.
Score 1
2 Comments:
Hi, I tried a lint roller and after a quick wear the dust appeared again. When I did my first washes I followed the listed instructions. Thank you
by
hi joshua, may i know if you've solved the problem or if the thing has stopped after wears. many thanks.
by
Add a comment
This is likely due to the waterproof lining that is applied either on the exterior shell or internal lining. Wash will actually make it worse. If it’s internal there is no fix. If yuh hold it up to bright light you should see the dust piled up inside! Kinda gross!
Add a comment
Add your answer
Joshua Konya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,613
