I have the XBR-65X850E
Im pretty sure lightning struck my outside antenna and ran thru the cable inside my tv. Now i have no power to the tv. Electrical outlet is fine and working.
@binkster32 you will have to remove the back from your TV to inspect for any damaged components on your boards. Check the fuses on the power board, check for charred or missing components. Usually with lightning you end up with a damaged main board 1st and then power board 2nd. Let us know what you find.
Post some good pictures of your boards with your question so that we can see what you see Adding images to an existing question
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 369
