The ASUS X44H-BRR4 is a laptop that was released in 2012 and has an intel core i3 processor.
5 Questions View all
Black Screen on my ASUS X455L
my asus X455L doesnt seem to open the light is lit but the one near the power botton is not blinking at all it should be blinking when my laptop is on and i cant seen to know if its on cause of the black screen i conncet it to my pc's monitor but it seems that i cant connect its also black and the pc's monitor in not turning on maybe the hdmi is the problem? my screen actually never open in my laptop but just a little while it turned on and then back to a black screen a already tried draining the exess bat. but it doesnt still open. and also i dont know if it had a ram on it?
what should i do?
please help
thanks
Add a comment
1 Answer
To check if your RAM is working properly and how much RAM is installed on your computer, refer to these articles:
https://www.techjunkie.com/check-ram-wor...
https://www.computerhope.com/issues/ch00...
With your system on, disconnect all of your external devices. This includes your mouse, keyboard, external hard drive, and so on. Restart your computer and see if you still get the black screen. If you don’t, plug each device in one at a time until you find what’s causing the problem.
As you have connected to an external monitor and screen is still black, it could be an issue with the video cable. You can try with a new cable. Make sure your cable supports the correct version of your display standard.
Add a comment
Add your answer
Mark Tabor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 587
