The Sony Xperia XZ1 Compact is a compact flagship Android smartphone from Sony released in October 2017.
11 Questions View all
Is it ok to glue the xz1 compact top lid?
The thin metal piece at the top of the phone detached from the phone after a fall. Everything still works fine, but still, i’d rather have it attached. Is it ok to glue it, and if so, what type of glue should i use ?
Thank you !
Add a comment
1 Answer
Most Helpful Answer
@anoyo anytime you need to glue something back, you want to make sure you are using an adhesive that will allow for future disassembly if so desired. I prefer to use epoxy adhesives like Gorilla Epoxy etc., personal preference for sure. If you do not to take it ever again apart remember that you require heat to do so :-)
Score 1
2 Comments:
Well, for me the lower lid deattached. What can I use to attach it back in, the phone works just fine. Anyways, what can i use and where do i buy expescially for the Sony Xperia G8441??
by
@Luccafo I'd be using E6000
by
Add a comment
Add your answer
Anna Onymous will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 321
