The Alienware M14x is a laptop designed for optimum gaming experience and content.
2 Questions View all
Laptop GPU reflowing- help needed
Hi I want to reflow the gpu on my only laptop by myself, I can't trust repair center or can't effort a new laptop .
I kind of bent the main board so this happened.
Question : I want to reflow gpu using heat gun and laser thermometer for measurement , what's the best melting temperature for it? I saw people go up to 260 but I usually solder joints melt at 200-210 Celsius , so I'm wondering if lower temperature will reduced the risk of burning the gpu completely…
Add a comment
1 Answer
Most Helpful Answer
@javid_zare_s a reflow is not going to fix a bend motherboard. If the solder connections or pads have come loose they will not go through a reflow. Remember that a good reflow is more than just blasting an area with a hot air gun. Anyhow, I suggest you follow the profile as outlined on here
Score 1
Add a comment
Add your answer
Javidzed will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 477
