The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
72 Questions View all
Location of blower resistor
I have removed the cowl and found the hole it is supposed to be located in, but I feel nothing inside the hole. I called the dealership and they told me I should see it again I see nothing inside the hole I feel nothing inside the hole. So please help me figure out the location of the part number RU479 I am trying to install in my Dakota sport.
1 Comment
mommy_luvz_u it is easier if you post some good pictures of what you are looking at etc. That way we can see where you are at and can most likely provide you with some decent answers. Adding images to an existing question
by
Add a comment
Most Helpful Answer
Hi,
Has the blower motor ever worked?
If not, the resistor may have been removed and the harness connector pushed back in out of the way, due to some other problem. Just a thought.
Here’s a link to the relevant section from the 2000 Dakota Sport service repair manual
Scroll down on the page in the viewing box to find p.24-3 and p.24-25/26 to view the location of the blower resistor, and the necessary pre-requisite steps to remove and replace the resistor.
Here are some of the pages if you have problems.
(click on images to enlarge for better viewing)
Hopefully this is of some help.
Score 1
Add a comment
remove dash (at least tilt it back) blower resistor located middle of windshield under dash
Add a comment
Add your answer
mommy_luvz_u will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 114
