Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Clean Windows installation on new SSD
Hello!
I have iMac Intel 21.5” late 2012.
My HDD is failing and I want to replace it with SSD. SSD is new and I plan to install Windows on it. I don’t want to install OS X.
I have Windows boot USB — used it before to install Windows on old HDD. The difference is, old HDD already had OS X installed, new SSD is clean.
Can I just replace hard drive, insert USB and smoothly setup Windows? Or I need to install OS X first, then use boot camp etc. ?
What are the steps?
Add a comment
1 Answer
Most Helpful Answer
Hi leo, I have an Imac mid 2011 27inch that I did exactly this on but I did not write down any steps. I ended up using OSX on the SSD. at any rate I found a few guides that look fairly decent.
https://www.intowindows.com/how-to-insta...
https://www.wikigain.com/install-windows...
One word of advice. If there is anything on that old drive you care about make sure you back it up in two places before touching the machine. I backup to the cloud as well as to a local drive.
When I installed windows 10 on the mac I simply created a windows 10 boot thumb drive and booted from that after I installed the SSD. I then let windows partition the disk and install as normal. it worked fine but I decided to go back to OSX as I did not have a license for windows and did not want to purchase one. besides I like OSX just as much as windows. I find it more stable by a long shot.
I did make a video on tearing down and replacing the hard disk on my system. I don’t remember if they went to the slim case in 2012 so if they did my video wont be much help.
https://youtu.be/vQ5sS6H1NaE
Score 2
Add a comment
Add your answer
Leo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 1,095
