The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
279 Questions View all
Why is my controller not charging?
Recently, which is a little over a month ago, I have bought a new controller for my PS4. It was working great when out of the blue it randomly stopped charging. When I say charging I mean that it doesn't charge in the PS4 nor a wall outlet like it could before. I also switched different cords and it still doesnt charge. Can anyone offer any help/guidance?
Score 1
Add a comment
Hi,
Have you checked if the Micro-USB port isn't broken? If you bought it as new, you should be able to return is as it is under warranty.
1 Comment:
Yes I have this problem too the difference is I’m trynna fix that but I’m stuck on this one screw it’s not Philip screw it’s like they used a different screw on one of the holes and left every other one Philip my controller won’t charge and I’m trynna replace the usb wit one that works perfectly fine
by
Add a comment
Like what @gotowiec27 said, if you bought new, you should be able to warranty the controller. Otherwise if you want to tackle the troubleshooting yourself, try getting some contact cleaner first. Squirt a little into the charging port and insert the charging cable a couple times to work in the cleaner. Sometimes a little gunk or buildup can disrupt the connection. DeoxIT:
DeoxIT® Connector Cleaning Kit
If that doesn’t work, try your hand at this guid to replace the charging part assembly altogether:
DualShock 4 Charging Port Replacement
@yungloy , your link is 404’d so I can’t see the screw you are referencing.
Clean and deoxidize electrical contact surfaces in cell phones and other electronics. Image
Product
$6.99
3 Comments:
Can u look at that and help me what screw driver I need to open my controller
by
@yungloy your link still gives 404 message
by
How do I send pictures of it to you
by
Add a comment
Add your answer
Dominiq Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 363
