6th generation of Motorola's Moto G line. This phone was released in 2018 and features a glass back that is easier to remove than Samsung phones. Model numbers are XT1925-4, XT1925-5, XT1925-6, XT1925-12 and XT1925DL.
36 Questions View all
How to replace the usb type c connector?
I saw the video from a few years ago where Andrew worked with Jessa to replace the USB connector on the Glalaxy S3 but that was a regular USB port
I was wondering if anyone tried to do the same thing with the USB-C type connector
I noticed on the video that it was installed with the soldering iron by soldering the pins to the pad
The problem with the USB-C is that it has 2 rows of pins so there is no access to the inner rows so you can’t use the soldering iron so the hot air needs to be used
The problem I am having is that by the time the solder melts the plastic material that separates the pins starts to melt at a lower temperature so it damages the connector
What is the best way to install this type connector ?
Can this be done with just a hot air station or do I need to preheat it from the bottom maybe ?
1 Comment
Sta Tus not sure who Andrew and Jessa are but in your case you want to post some good pictures of your board (both sides) with or without USB C connector (as well as your replacement connector) and lets see what you have going on there. Post the pictures with your QUESTION. Adding images to an existing question
by
Add a comment
1 Answer
Most Helpful Answer
Sta Tus until we see what you have going on with your board, the general rule is that you remove the old connector with low melting temp solder and hot air workstation. Use plenty of flux to remove the old connector so you do not tear the solder pads etc. To install the new connector you should preheat the board and use micro soldering iron and preferably 70/30 solder. You most likely will need a microscope to really see what you are doing. So, as you can see it can get pretty involved. If you have never done this kind of repair I would suggest you find a micro soldering expert to do that for you. Your motherboard will not be a good place to start practicing :-)
Of course you could also see if there are metal Type-C connectors for your phone like these
Score 1
1 Comment:
Thanks for the reply
I thought maybe you would know Andrew as one of the employees at Ifixit but maybe he doesn't work there anymore Not important
The usb-c is exactly like the one you show in that link
As you can see it has 2 rows of surface mount pins so while I could solder the outer pins I have no access to the row of pins behind the first row
I have a microscope so that is not a problem The question is how to get the second row soldered before the plastic melts all around it
So you are saying using the 60/40 solder would be more difficult to solder it ?
by
Add a comment
Add your answer
Sta Tus will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 20
All Time: 524
