The Nikon D500 is a prosumer DSLR Camera released in January 2016.
Metering Mode button not working
On my D500, the Metering Mode button isn’t working. The other 3 buttons (WB, QUAL, and Mode) are working. It has already been into the shop once (6 weeks and $150) to just be told there was nothing found and it’s working now!
A couple of times, a sharp hit to the top left corner would have the button working again, but not this time.
Since I’m in IT, I suspect it is just a cable that is loose.
Is there a teardown of the D500 that shows where all the screws are that I need to remove?
Add a comment
1 Answer
Chosen Solution
I have opened it up myself, and reseated the connector inside the top assembly, as it was out of place. When I put it back together, it didn’t work, but a 2nd reseat worked to get it functional, not sure why.
I am going to work on making a repair guide; not sure when it will be ready.
I have created the guides of the steps that I took to resolve my issue: How to Fix a not working metering mode
1 Comment:
Thinking the first attempt, I may not have seated the tiny cable just right, and had to do it again. I am at 6 months, and it has not had any sort of failure of the button.
by
Add a comment
Add your answer
Wolphin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 339
