Hyundai launched a redesign of the Santa Fe on February 14, 2012, and went on sale in June 2012 as a 2013 model.
17 Questions View all
Car vibrate at 70-90 km
My car vibrates at 70-90 km and once I cross 100 it become completely normal, I thought it might because if tires balancing but I got the balancing done and it still continues, does anyone know what’s the problem thanks
4 Comments:
Does the steering wheel also vibrate?
by
Yes I can feel it, the whole car vibrates
by
Jignesh Patel yours the All Wheel drive model?
by
No fwd 2.4 litre engine
by
Add a comment
You likely have out of balance CV assembly
These are the symptoms of a bad or failing CV axle shaft assembly
1 Comment:
I will have to check with my mechanic.
by
Add a comment
Jignesh Patel  rotate your tires or change your tires. Have a good mechanic check your front end including the ball joints and tie rod ends.
1 Comment:
I rotated the tires but still the same problem, in fact, I changed my all-season tires with Winter tires and still have the same problem.
by
Add a comment
Add your answer
Jignesh Patel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 243
