Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Error 4013 bootloop on iPhone X
Hello!
Today I am getting the apple boot loop it is asking me to connect to iTunes.
From previous, I already had a crack on the left bottom corner of the screen.
Today when I noticed this problem, my phone was kept in the rest room close to water but I am not sure if water entered or not.
I took it to the apple store and they said it is because of 4013 error and asking to restore.
Before doing that, I wanted to get my stored data first because I am not sure whether I will be able to get my data back or not during this process.
So, please, does someone know a REAL solution to this problem or any shop where I can take to fix it?
My priority is to get my data back.
Thanks in advance.
Add a comment
Most Helpful Answer
If the Apple logo during the start keeps coming off and on constantly, the short answer is, you probably cannot do anything about it, because it is likely the mainboard issue. You are stuck with a motherboard replacement cost of about $750 CAD (I'm Canadian) as Apple doesn't take ownership when its devices fail after the warranty period.
I had had an issue with my MacBook Pro 2015 too, the anti-glare coat was pretty much melted on the monitor due to a manufacturing error. When I took my MacBook, I was told that they cannot do anything, because I didn't bring it during the recall for a free replacement. I had listened to the same song by then, the song's name is: It's Apple's Company Policy for its lemon products. I later learned that it was called "Staingate".
It's so disappointing that Apple doesn't take ownership of its poor-quality electronics and there is no credibility. Wishing all the best of luck to all current and future Apple users, as you folks have a very frustrating and expensive route ahead.
Score 1
1 Comment:
So basically keep up that expensive warranty insurance or don’t update your iPhone. Which is BS. Really disappointing
by
Add a comment
Try dail “*#06"#”.
If you can’t see your IMEI, then you got a problem with your baseband.
1 Comment:
How can i fix my iPhone X baseband problem
by
Add a comment
Remove charging flex and check most of that cases on iPhone X have such problem throw vibrator circuit shorting on charging flex.
Add a comment
iPhone X ERROR 4013 SOLUTION - REALLY BIG HINT - THE ERROR 4013 MYSTERIUM SOLVED
https://www.youtube.com/watch?v=JM-04aWO...
1 Comment:
It’s in German ?
by
Add a comment
Add your answer
Shal S will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 3,565
