The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
694 Questions View all
What classification of screws are used?
I lost one of the screws for the joy con wrist strap connector, and I can’t find any identical ones anywhere. Does anyone know what they are? I think they’re a metric classification, maybe M1.6x1 ?
Add a comment
Hi Nate
No idea what the exact size screw is but these kits are available that include all the screws for the device.
Add a comment
I have measured the Joy-Con Strap rail screws as JIS00 M1.4x6mm Thread Forming. PH00 should work if your drive kit does not have the J set. Hope this helps.
The closest screw I found on McMaster-Carr is 96817A800 with the key difference being the head is 0.45mm thick and 3.25mm in diameter.
Being a thread-forming screw, be sure to slowly drive the screw in reverse until you hear/feel a subtle 'click' as the screw settles into its previous threads, then you can drive it in to avoid creating new threads.
Add a comment
Add your answer
Nate Spurgat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 78
