2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
435 Questions View all
MacBook Pro retina 15” screen replacement
I’m replacing my screen. I got one from eBay and it had the A1398 but did not work at all as if the screen I got were a “dead on arrival”. I based my ordering criteria by the date when I bought my mac, March 2015. I found an Apple receipt and it says “mid 2014”. When I told the gentleman whom I bought the replacement screen, he mentioned that a 2015 screen will not work for a mid 2014? Is this correct? I thought all I needed was A1398. Did I need to include the EMS 2881? Can someone please tell me how I may be able to get the exact screen part number I need? Do you have the part I need? If so please send me a link. Thank you in advanced. B
Update (11/21/2019)
No luck on picture. Here’s s/n: C02P62CPG3QD
2 Comments
Apple MacBook Pro "Core i7" 2.5 15" Mid-2014 (DG) is your model with dual graphics.
https://everymac.com/systems/apple/macbo...
The EMC number is helpful for indentifying macbooks as it narrows down compatible parts as well.
by
Hello, I am needing to replace my display on my MacBook Pro Mid-2014. Here are the computer details ... MODEL A1398 EMC 2876 SERIAL# C02NL35ZG3QC What is the correct part number to replace the screen?
by
Add a comment
Chosen Solution
The Apple P/N you require is 661-8310
Here’s the needed part MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly iFixit only has Grade-B & Grade-C used parts while cheaper do have some visible defects. TheBookYard in the UK has a new part for sale Retina MacBook Pro 15" Complete Display (13/14) as you can see the cost is even higher! The older retina models are still highly sought as they have the ports onboard! Which is one of the reasons the price of parts is high as the availability of new parts is getting tight.
Replace a display compatible with the model A1398 Late 2013 to Mid 2014 MacBook Pro 15" Retina laptop. Includes the 2880 x 1800 pixel 15.4" Retina LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables. Image
Product
$319.99
Score 1
1 Comment:
Thank you Dan you are the man!!!
by
Add a comment
Most Helpful Answer
Search up the Mac's serial number located under the bottom of the Mac which is near where the a1398 label is located.
A1398 tells us that it is a MacBook Pro Retina 15” model. The problem is that even if the screens are identical they are not compatible with different year / mid-late-early models unless specified otherwise.
Once you have the serial number you can input that on everymac.com with the ultimate serial number lookup page.
That will give you the exact model of the MacBook which you can search based off of to find compatible replacement parts.
That is correct the 2015 models are significantly different to the 2014 models.
Score 1
3 Comments:
Now I need the replacement screen!!! How may I be able to get one? Do you carry it at ifixit? Help please. Thank you. B
by
If we don’t carry it at your store, are you affiliated with any other stores that you trust and recommend where I can get my screen?
by
@B - @benjamen50 as well as my self are volunteers here on the iFixit Answers Blog. We both believe in repair & reuse iFixit stands for and the 'Right to Repair' movement!
by
Add a comment
Add your answer
bboy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 59
All Time: 3,630
