The 8th generation Honda Accord
35 Questions View all
Changed cranshaft and camshaft sensor both but engine light shows up.
My car is Honda accord 2011 and it has 55000 miles on it. I got to change the crankshaft sensor as the car stopped in the middle of the road, i got freelancer changed it for me, afterward the engine light didnot went off and the mechanic told me I had to change the camshaft sensor too, But After doing so the engine light still on and make longer crank sound and engine light still on, does both of them need to be relearned or there are any other problem with the wires of the cranshaft or camshaft???
3 Comments
your mechanic does not know what he is doing, simply changing the parts may not turn off the light, you need a code reader or more expensive piece of equipment to turn off the light. The light is giving you a code that requires a code reader to give you that information, We need that code to help you please.
by
The code i got is P0339 P0341 P0340 at the same time
by
I went to the Honda Maintenance and Repair, and they told me that I had to replace the timing chain, timing chain tensioner, Guides, VTEC Actuator, Front Crank Seal, and VTEC gasket.I believe they did not do the relearn process and wanted to give the more estimate. When I run the car clearing the error code from OBDI scanner , the car runs good. And is not it to early to change the timing belt at 55000?? They gave me the estimate of $1300.
by
Add a comment
Most Helpful Answer
Most likely, you'll need to either take your own OBDII reader and reset the engine codes or find someone who has one and have them reset the codes to get that light turned off. Chances are, everything is fine, it just hasn't been reset in your cars
Score 1
Add a comment
the sensors shouldn’t be going faulty at that mileage, they are telling you something is wrong, probably one of 2 things, if you have replaced the sensors check the wiring for them isn't damaged and get your timing checked, couple of symtoms of bad timing are car randomly stalling, issues trying to start it, those codes may pop up, fuel MPG will go down. get a mechanic to check and give you a diagnosis, they may clear the codes and k you to drive it until they re-appear again. if its timing related don’t leave it to get worse as it may cost you an engine rebuild if something snaps and the valves hit the pistons.
Score 1
Add a comment
Add your answer
aahabiki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 3,503
