The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
142 Questions View all
What screwdriver do I need to open the battery panel? MacBook Air 2015
I spilled a little vinegar on my laptop days ago. I’ve just got the right screwdriver to open the back of it but I’ve discovered that I need two different screwdrivers to open the battery panel. Where can I get this in stores! Please help! Thank you. MacBook Air 2015
Add a comment
1 Answer
Most Helpful Answer
Here’s the iFixit guide you need to follow: MacBook Air 11" Early 2015 Battery Replacement
You need the following screw drivers:
T5 Torx Screwdriver Image
Product
T5 Torx Screwdriver
$5.49
P5 Pentalobe Screwdriver Retina MacBook Pro and Air Image
Product
$5.99
Score 2
3 Comments:
My laptop isn’t turning on. Do you think the batteries are just the problem? Where do I get new ones?
by
Before you jump into getting a battery. How about doing some basic tests.
When you plug in your charger what color is the MagSafe plug Amber or Green?
If the charger is not lighting inspect the contacts for damage and clean the contacts if needed.
Is the charger the correct one for your system?
by
The charger lights up when I plug it in. It turns from green to amber. I don’t want to start my laptop again because it shortens it. When I start it it turns on and then shuts down real quick. I can’t believe it’s not working. When I spilled a minuscule of liquid on it and wiped it up right away. I don’t see any corrosion inside nor any liquid. I don’t know what’s the problem. If you could please help me thank you
by
Add a comment
Add your answer
aimee will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 30
Past 30 Days: 155
All Time: 7,525
