GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Questions View all
iPad Mini 2 only powers up on charge but bootloops and then gets stuck
My iPad is on iOS 10.3.3. I cracked he screen and the battery etc was disconnected for a week now. Popped the new lcd and digitiser in and tried switching it on but the device did not switch on. I then plugged it into a wall adapter and saw the Apple logo (finally). But then the device started bootlooping on the Apple logo. I hard reset the device and eventually I was led to just a blank screen. I left it on charge over night with no luck. Whenever I disconnect the charger the device switches off and does not switch on again.
Add a comment
1 Answer
Most Helpful Answer
Latif Abdul  all of this sounds like a bad battery. Replace the battery with a new one and re-evaluate. If nothing else it will provide you with a known-well starting point should further troubleshooting become necessary
iPad 2 GSM Battery Replacement
Score 1
Add a comment
Add your answer
Latif Abdul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 61
