HELP! Samsung Galaxy a10- it has vertical lines after splash of water
Please how to fix this problem, do i need to change the LCD or what?
its been wet for about 11 seconds
@angelolerado it does not matter how long it was exposed. What matters is where it was exposed. In your case you do want to start with a new display. It is possible that this is a shortened component on the motherboard but for now you will have to start somewhere. Best to start with the display. Once you have your phone disassembled, clean the boards etc. with high grade (90%+) isopropyl alcohol and a soft brush. Clean the connectors etc. Check the board for obviously damaged looking components. Post some good pictures of your board with your QUESTION. that way we can see what you see. Then replace the display and re-evaluate. Adding images to an existing question
i edited the question with the motherboard
جوالي استخدمت عليه معقم على الشاشة
وطلع زي الدواير البيضاء في الشاشة كانك تشوف عليه بقع زيت لكن من داخل الشاشة ...ارجو المساعدة جوالي انكب
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,882
automaticaly proximity sensor bilinking. how to solved
by ELAVAZHAGAN
