Replacing the capacitor to the compressor in a dehumidifier
Seeking advice on replacing a capacitor to the compressor in an dehumidifier. The capacitor in question is a CBB61 3 wire 7uF 450V one, made New Tech. It is also rated at 50/60Hz
I have searched all over the internet to try to find one which is of the same ratings, with 3 wires to allow for a straight swap, however 3 wire capacitors do not seem that common, especially at the above values. I am instead now looking to swap it for a 4 wire capacitor or 2 wire capacitor and was hoping for some advice on how to go about doing this. The capacitor has one wire from the dehumidifier's main board which connects into it. 2 wires, a red and white then lead away from the capacitor to connect to the compressor. Any advice would be greatly appreciated! thanks in advance J.
Edit: Extra photos of the ID sticker of EasyHome dehumidifier and the capcitor at a different angle
9 Comments
I think one of the wires is a ground wire
by Brayden S
@fegelein3290
Thank you Brayden for your reply, just as an aside, do you think it would be safe to bypass the ground wire if i use a 2 wire capacitor to replace this 3 wire one? Thanks in advance :)
by Vish Sapa
Yes, I believe it’s possible. In the picture I don’t see the third wire
by Brayden S
Hi @vishsapa ,
What is the make and model number of the dehumidifier?
by jayeff
@jayeff Hi Jayeff, thank you for your reply,
The model is an EasyHome, A brand sold through Aldi in the UK. I will see if i can post a picture of its ID sticker
by Vish Sapa
Show 4 more comments
