Repair information and disassembly guides for wireless Xbox One and Xbox Series X|S controllers.
My controller isn't turning on and is showing a dim light when I click
I have the Xbox one controller model 1537 I believe. Its not wanting to turn on and shows a dim light. If I plug It in or out a battery pack in and click the middle button it shows a dim light that varies on how bright it wants to be. After that it instantly turns off if you release your finger from the button.
Score 1
Add a comment
Most Helpful Answer
Have you tried another battery? If the battery is starting to go flat it will cause the controller to do that.
Score 1
1 Comment:
Yes I've tried different batteries, battery packs, and even a cord. I thought it was that at first.
by
Add a comment
Shim the little metal flap on the back of the battery pack. This pushes it out so it makes a solid connection to the row of pins on the controller. I used a flat blade and pried it out a little and shimmed with folded aluminum foil. Has worked for a week without issues.
Add a comment
Add your answer
Max Thomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 37
All Time: 6,199
