The Asus X551M-RLN03 is part of the Asus X-series. It is a 15.6 in notebook that runs on Windows 8 with an Intel Core Processor.
7 Questions View all
Laptop has a shortage
I tried to plug in my headphones and touched another port. As soon as the metal tip touched the other Port my computer turned off immediately and will not turn back on. No power buttons are on. Is this an expensive fix or something I can do.
Add a comment
1 Answer
Most Helpful Answer
@stacyedwards depends on what other port you touched and which part got shorted out. you will at minimum need to look at it. Check the motherboard for any obviously damaged components etc. Then you need to identify the motherboard. There will usually be a maker and model number silkscreened on the motherboard. Let us know what you find on that. You cdan always add images to your QUESTION in case you get stcuk or have further questions etc. Adding images to an existing question
Use this guide to at least get into your laptop. Asus X5511M-RCLN03 Battery Replacement
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Asus X5511M-RCLN03 Battery Image
Guide
Difficulty:
Easy
2 - 8 minutes
Score 1
Add a comment
Add your answer
Stacy Edwards will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 54
