What screw size is it?
I have Asus Zenbook ux430u and I want to replace some parts but I don’t know which screwdriver I should use.
T5 or T6 for the Zenbooks - it depends on which one you have, so I would get both just in case. It isn’t a TR Security at least, so that isn’t an issue. More then likely it’s T5 because that’s historically what Asus uses in the Zenbook, but T5 and T6 are very similar looking to a point on devices like this, it’s best to have both. It uses Phillips #00 screws like nearly every other laptop in the PC sector internally.
I would also get the 64-bit driver kit just in case it’s something obscure even what information I have doesn’t apply. You’re better off with the 64-bit driver kit since it isn’t that much more, if you want to save a few bucks, the Marlin screwdriver set will work. This only has the T6, so you’re taking a chance on if it will work or not as well.
Product
$39.95
Product
$19.99
thank you very much:)
does anyone know what the actual size of the screw is as well? I'm trying to find replacements but I can't tell what the size is.
@Talal Hasan Usually Asus is T5 - look up the model and you'll know right away.
Guys, I lost them after I removed the screws. Can you tell me their model number? (like M2 * 4). There should be two kinds of screws on the D side.
@zpp eBay. Buy a bunch of them for a few bucks, but keep in mind unless you seek out T5/T6, they will be Phillips.
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 313
All Time: 14,303
1 Comment
TORX T5. You'll find this in many kits.
by John Walshaw
