The Acer Nitro 5 AN515-53-55G9 is a laptop targeted towards budget gamers. It boasts 256 GB of storage, Nvidia GeForce Graphics and an Intel i5 quad-core processor at a more affordable price than most gaming laptops.
60 Questions View all
Wifi adapter keeps dying
So just yesterday I went completely offline and when I checked the wifi settings, it just showed up with no wifi connections and when I hit the troubleshooter, it said there were driver issues, yet it couldn’t fix them. I downloaded and installed the drivers from the acer support website, but it just happened again this morning, is there a way to fix this for good? It’s only just started happening ever since I updated the system to that whole new windows 10 version where everything’s changed and I can’t revert it!
I’m thinking these may be helpful:
Thanks for all the help!
Add a comment
1 Answer
Most Helpful Answer
Hi @theandroidkid
Try the following:
Uninstall the WLAN adapter in Device Manager
Clear the TCP/IP stack by performing a TCP /IP reset
Restart the laptop.
Check in Device Manager that the WLAN adapter has the latest WLAN drivers installed. If not, then install them
Check if the problem is resolved.
Score 2
4 Comments:
Okay, I have tried it, only time will tell if it was successful.
by
okay idk if this would fix mine but it kinda sounded like the same problem for me so I went ahead and did this hopefully I didn't really mess something up but I have bad connection when I move anywhere and it's not my internet or the hot spot so I thought it was my computer plz tell me you know of something else to update on my drivers or something i should do
by
@Cody Kost
It may be a loose antenna connection in the laptop.
if you go somewhere else and you know where the WiFi router is physically located (not easy to know this I know, unless you mean at home) try using the laptop as close as possible to the router. If there 's a good stable connection its looking like an antenna problem.
What is the make and model number of the laptop?
by
I just bought an Acer nitro from a pawn shop and to make a long story short, the wifi adapter (radio) is wore out. I'm waiting for them to fix it but looking at the prices on eBay, I would say just replace the card. It's about as easy replacing memory. The prices I saw were lesss than $15. I was a network administrator in my career (disabled now). I would replace the card before attempting anything with the antennas because on those gaming laptops to antennas wrap around the edge of the laptop itself and it can be a nightmare. Just my two cents. Hope it helps. Good luck
by
Add a comment
Add your answer
Bryn Trainor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 953
