Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
197 Questions View all
Apple Watch series 3 no touch after screen replacement
I recently replaced the screen on my Apple Watch series 3 Nike + edition. The screen comes on and the buttons work but there is no reaction from the device when I touch the screen. I have tried force restarting it dozens of times and it has changed nothing. The old broken screen does not work at all so I believe that trying to use the old digitizer will not work. Anyone have any ideas?
Score 2
Add a comment
Chosen Solution
Sounds like either the display assembly was defective or the cable connection from the SIP was not fully inserted and latched or was damaged.
Score 1
4 Comments:
I have tried reseating the cables a couple of times and that hasn't changed anything, unfortunately, so I am beginning to wonder if there is another component that might be damaged or if the unit is now useless
by
I went back and tried your solution and to my surprise, it worked! I can't believe it was that simple of a solution, thank you!
by
What exactly was the solution? @Blake Russell
by
@chi.areadj - Either the cable was not fulled inserted or the display unit was defective.
by
Add a comment
Blake what was it that you did exactly? I am having the same problem…I can’t get touch to work. The touch cable appears to be seated into the connector…I’m stumped
1 Comment:
Hi Jerrod, did you ever resolve the problem with your watch? I have the same issue.
by
Add a comment
For me the solution was update the firmware and after the touchscreen start to work fine.
1 Comment:
I purchased one of these sapphire screens for series 3. Screen works but in constant restore loop. Firmware upgrade fails each time also
by
Add a comment
Add your answer
Blake Russell will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 91
All Time: 4,253
