The ASUS ZenBook, which can be identified by the model number UX330U, was released in March of 2017. The UX330U is also referred to as the UX330UA in some regions. The ZenBook uses Windows 10 and features up to 12 hours of battery life, a QHD+ Display, and a lightweight and slim profile.
9 Questions View all
UX430U wont boot up unless hard rebooted with battery disconnected
Recently, I dropped a few drops of water around the power key of my laptop. It did not show any issues then, but after shutting it down, it did not boot up. It shows as charging if plugged in though.
Taking it to folks at geekbench resulted in a temporary solution where hard rebooting with battery removed (and power attached) leads to the laptop turning on. Now the laptop needs to hard booted that way or else it wont boot up.
Any suggestions what might have gone wrong
Add a comment
1 Answer
Most Helpful Answer
@pscoe2 possible that the battery is shortening it out. Replace the battery first. If that does not work you have a short circuit on the charging circuitry. You will need the schematics for your motherboard as well as the board view for it to a. check on it and b. possibly repair it if you have knowledge and tools for board level repairs.
Score 2
Add a comment
Add your answer
Puneet Singhal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 532
