2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Is there a way to change the low battery warning threshold?
I have a slightly defective battery. The battery thinks that its capacity is higher than it is, and my system completely shuts off when the reported capacity hits 28%.
This actually isn't a huge problem-- I'm pretty diligent about watching it and getting plugged in before I hit 28%. BUT it would sure be great to get a low battery warning when I hit 38%.
(The ideal solution would actually be to reprogram the battery to think its capacity is accurate, but I don't think that's feasible without accessing its internal electronics.)
Score 7
1 Comment
It is possible to reprogram the battery without removing the battery from the laptop. Click here for a video discussing the topic. The White Paper on the subject and tools used can be downloaded if you click here
by
Add a comment
1 Answer
Chosen Solution
Sure you can. There's a couple of different routes you can take:
Check out this MacOSXHints forum post on how to set up an Applescript that gets triggered at a certain battery percentage.
There are also 3rd party battery warning applications available, such as SlimBatteryMonitor, that lets you set the low battery warning level to whatever percentage you want.
Score 5
2 Comments:
For wanting to add a certain feature or ability (like setting macbook to warn you when battery is a certain percentage low) Which route is preferred, setting an Applescript, orgetting a 3rd party app? (Wondering if adding apps may be not as ideal, because maybe each app you add might cause potential problems (compatibility issues, etc..)? Or am i guessing wrong? Thanks for explanation! :)
by
It states that this issue has been solved but without a reply from Miroslav, we have no idea if any of these solutions worked. I too have "lost" the low battery warning from my 2009 macbook pro and have yet found a solution for getting it back.
by
Add a comment
Add your answer
Kyle Wiens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 24,390
